Willsenton R8 MKI - Finished Mods
Hi all,
I have done following modifications on my Willsenton R8 MKI amplifier:
1.) Power supply mods, remove 115V/230 switch - Sonic (no hiss or hum), SQ
2.) Voltage Regulator Mod - Sonic, SQ (removes crosstalk, lesser noise floor, darker background)
3.) Bias Boards Mod - Sonic, SQ (smooths the sound)
4.) Grounding Mods (headphones wires removal and input relay board grounding)- Sonic (no hiss or hum), SQ
5.) Grid stopper resistors 1kx4 on output tubes - Reliability, Safety, SQ (smooths the sound) 6.) Choke replacement - Reliability, Safety
7.) Power supply caps replacement with min. 500V ones - Reliability, Safety
Optional
8.) Replace capacitors with higher grade electrolytic or polypropylene capacitors (Nichicon, Mundorf). - Reliability
9.) Replace all resistors with Vishay PRO metal film resistors - Reliability
10.) KT88 heaters wires rerouting and removing grounding jumper from heaters - Reliability, Safety
11.) Global Negative Feedback - GLNFB - Ongoing... I have tested with 24K resistor and 220 pF MICA cap but it my case that does not work correct. The ringing on sqaure signal is gone but the output power dropped in UL Mode from 38W to 22W.
After all job done I'm pleased to confirm everything that Stephe said or demonstrated in Willsenton R8 series.
Thank You Stephe for posting all these valuebale videos and documentation!!!
Best regards,
Robert
Skunkie
Skunkie
Nov 18, 2023
Thanks for the update!!!
