Public·393 members
Thoughts on Luxman MQ-300 using parallel 6SN7 drivers & dual rectification?
I recently came across this amplifier and was wondering from a design perspective what advantages it might have. It's essentially like many single ended 300B's we have all seen here, with basically a full dual-mono power layout even using 2 rectifier tubes. It's also got a small change here of driving the 6SN7's in parallel by using both triodes at each stage.
This amplifier is also ridiculously $$$ expensive, but I'm a bit curious about the potential of trying this as a DIY project. Would similar values of resistor and capacitance still work with this parallel drive design? I'm a bit fuzzy on what the advantage would be but I'm guessing maybe higher current?
Levi Kendall
Levi Kendall
Apr 22, 2023
Also, anyone have good suggestions how to fill in some component values and/or specific parts that would be a match?. The primary transformer seems to have a lot of additional windings on it so I'm guessing it may be difficult to get a single part when this one might be designed specifically for this application.
