Public·393 members
spchristenspchristen
Tube Recommendation
I built and enjoy Skunkie’s EL34 amp earlier in the year.
I had been using JJ EL34L tubes in another amp prior to using them in the Skunie amp. I have noticed noisy tubes on amp power up. I didn’t think much of it until recently I started hearing some distortion. Swapping the tubes in the amp, the issue followed the tube.
I was going to order another set of JJs but wanted to see what tubes others are running or prefer.
To be clear, the amp did not cause this problem, I have had the tubes for a while. I’ve also been known to leave amps running overnight. By accident of course.
The JJs are a good value so likely I’ll get another set regardless.
ceymooney
2月15日
i have a few questions before making sugggestions: 1. to be clear, there is a noise problem that follows an EL34, correct? 2. how much do you want to spend? 3. does the skunkie amp require a matched pair EL34?
