EAR 834 and the Hammond 369AX Wiring
Hi Steph, Thanks for all the videos. I have watched them so many times. I am almost done with my build. It is a single-box build. I am currently in the US and will be moving to Europe soon. I bought the Hammond 369AX because I read that it could be wired for both the US and Europe. For the US, is the wiring the same as the 269AX? Do I have to do anything different?
I was also thinking of wiring it both ways, using a terminal block and a switch to go back and forth. Do you think that is something that could work, or should I just change it when I go to Europe?
Thanks,
Greg
The only difference is the primary wiring, You could use a switch, I'd be scared I might accidentally flip it so I would just rewire it when you get to Europe.
