Hi,
It took a while, but I put together an EAR834 clone using a Hammond 369 Transformer and 3 electro-harmonix 7025 tubes. I have built one board from scratch, and I also bought a prebuilt one to test as well to see if I was doing something wrong.
I have an st-70 that I tried as an amplifier and a cheap chinese one and both give me the same results. The first track is the sound it makes when it first gets power. IT settles down after a minute. The second clip is the music at about 1/3 volume and it sounds terrible. The recordings are with the board straight from ebay with no real modifications. I also have one I built and they both sound the same. The only thing I can think of is maybe the solder connection to the rca jack is not the best. I am using the same ones as in the video.
Any thoughts or ideas would be greatly appreciated.
Thanks,
Greg
I see you installed both the 68K and 220K on the output area, I normally don't install the 68K ones but I don't think that is the problem. I have seen them supply 68K for the ones in the 220K position, are you sure those are correct? It sounds super distorted like the output is overloaded.
Can you share pictures of your build with as much detail as possible. And yeah something is seriously wrong!
