Hi Everyone, I am working on a build, and everything is wired. I tested the power on the AC 230- 380V without the tubes in it. I got 300V DC, like the video shows. I then add the tubes, and I get nothing. I also don't get anything when I test the DC285V. I then check the measurements for the choke, and I get 70V, which seems very high for a Hammond 154E that has a max of 20V. Any ideas where I may have gone wrong?
Thanks,
Greg
Ground one lead and the start looking for DC, first on each side of the choke and then on the other large resistors and try to see where the voltage disappears.
Hi Skunkie, thanks for responding. I just wanted to update this to add more detail. This is my first build. I am using the board as one, I did not split it. I am not sure if that makes a difference. I tested the AC without tubes, and I get 300V. I tested it with tubes, and I get 256V.
I read the DC285 with the red probe and the black probe to ground, and I get nothing. The choke is installed ( I assume it doesn't matter which wire goes where in the 1k1 3w holes) . The transformer is a Hammond 369ax. On the transformer, since I am getting the right AC, I assume it is working ok. I have the white and brown wires go to the middle pin of the outlet. The two red go to the AC in the center, and the two green go to the AC on the left. The black and blue wire is going to the power switch. I also tested the first capacitor in the power supply side of the board, the 100UF 450V, which came to 326V. All the capacitors are what was suggested in the parts list.
The chassis is wood with a copper and aluminum plate as the top based. I will add some photos. As for the 20v, sorry I mixed up the specs on the 20mA as 20V.
Thanks again,
Greg
No sure where you got the spec that choke is only rated for 20V. It's rated for 300V.
