Hi all,
I will be enclosing my EAR 834 clone soon and am interested in installing a mono/stereo switch. Would a simple SPST switch tying both grids of v3 together present an issue? This seems to be the simplest way I can think of to implement it.
Any suggestions are welcome. Thank you
I 100% back up Skunkie in buying a real deal mono cart. I’ve also got an AT33mono, which sounds better than a stereo / mono switch or Y cables to sum the channels together. As Skunkie pointed out,, there’s a lot of “mono” carts available, but most are just internally summing the R+ and L+ outputs.
Before buying an AT33mono cart, I made my own “mono” cart by taking a stereo cart and wrapping a small thin wire around the R+ and L+ outputs of a stereo cart. While not a necessity, I put another wire between the R- and L-. I’ve found a figure 8 type pattern works best.
Then, just put the lead wires on the cartridge. By doing so, you’re simply summing the two channels together early in the chain, but just externally instead of internally. While it still won’t be a true mono cart, it can give you a taste of what a true mono cart can do.
But no, you can't just tie the grids together, you have to sum the channels with a resistor network. Google will show examples of this.
I can't recommend highly enough buying a real mono cart and make sure it's actually a horizonal only cart that doesn't read vertical movement for use with mono vinyl. Vertical compliance is fine, but some mono carts are just stereo carts with the outputs summed. The AT33mono is a real mono cart I swear by. https://dgmono.com/mono-cartridge-database/
