The value of these caps is not mentioned in the video where the resistors are changed although she said one is an Audio Grade. From the published BOM I think it might be these two. Can anyone confirm which is which?
Audio grade! 100uf 100V I assume this is the lower one
and
100uf 160V I assume this is the upper one.
Thanks.
Need to get the dimensions on the two large caps. The ones she uses have no part numbers.....
Honestly, I never get every part of the first order myself. But yes, all 4 of the caps on the 2 bias boards are 100uf 100V. So in total, including the one next to the power transformer, you need 5 of those.
Is the Bias board the same as the Power Supply board? I'm watching the video where you are changing the resistors and the two caps on the power supply board. You call out the resistor values but not the caps. I'm trying to avoid tearing into mine until I have enough parts to make a Mouser order and not get killed with shipping. And I suck at reading schematics. BOM's, wiring diagrams, and calling out values works for me unfortunately.
I'm understand what you are doing, but it's identifying the parts that's my downfall. wish me luck when I crack mine open and slowly start upgrading.
The bias board caps are 100uf 100V as shown in the schematic. There is one more of these 100uf 100V caps used by the power transformer, along with a 100uf 160V. I didn't post part numbers because not all of these have the same diameter clamps. if you have a 35mm one mouser # 598-380LX331M550A052 will work.
